Suspension Upgrade?
RE: Suspension Upgrade?
For under $1000 you can upgrade your shocks and struts (koni FDS from tirerack), lowering springs(also from tirerack), a full rear kmac kit (TTstuff), front and rear sway bars (if ECS is still having that sale front and rear for 2 hundred and something)... and you might even be able to get it installed. Of course you'd save more if you did it yourself. Just don't forget to get an alignment once it's all installed.
Coilovers on the other hand are a different story.
