stock boost...14???
RE: stock boost...14???
I wonder how lean your going when you hit 15psi, if your TT is stock because the stock program will only read 10psi that is it, nothing more. So something had to of been done to it if not your running lean most likely because the ECU is only throwing in enought fuel for 10psi and your running 15....i dunno just my thoughts. Unless your MAP is taking over then you may be ok, but I only thought the MAP took over when the MAF is disconnected? There was a guy earlier that had the same thing happeneing but we found out that he was hooked into a bad "boost" source, should be the FPR that your boost gauge is connected to, there are a few others but that one is the best and has the easiest axcess too.
ORIGINAL: 225tt
