Still weird engine noise after service
Old 05-24-2007 | 02:32 PM
joshuo's Avatar
Default Still weird engine noise after service
Hi, most of you may remember my post about a weird noise after i shut off my engine.
I took the car in for service yesterday, they said everything's fine.
however the sound is still there and it concerns me.
here's a video of it: it starts almost right after i shut it off.
video
Old 05-24-2007 | 02:37 PM
techbod's Avatar
Default RE: Still weird engine noise after service
very strange sound and im sure its not meant to be there, it does however sound like a fan slowing down
diehlryan's Avatar
I kinda like it.. does ECS sell that mod?
Old 05-24-2007 | 02:54 PM
joshuo's Avatar
if i hd to take a guess at it, i would think it's the turbo slowing down, because it comes from that area.
Is it possible for the turbo to not get enough lubrication?
cincyTT's Avatar
I'm make believe
Thats not the coolent sound and not the turbo/intake. It sounds like some squeeking as it slows. If you can give a discription of where it is coming from (inside car, engine bay, or elsewhere) would help. Check your fans and belts with the hood open and someone else turning off the car.
Old 05-24-2007 | 02:57 PM
WishIWasRWD's Avatar
I'm going to have to say... Muffler Bearings.
Have someone else shut it off while you are under your hood and see if you can narrow it down a little more. I agree that it sounds like a rotating part (fan) that needs to be lubed up.
Old 05-24-2007 | 02:59 PM
joshuo's Avatar
MUFFLER BEARINGS? explain what these are plz...
The sound comes from behind the engine, where the turbo and manifold and all the heatshieling crap are.
sure it can't be the turbo cincy?
its really weird, it seems like it occurs randomly, but never when the engine's cold.
Sometimes it's loud, sometimes very faint. the video is about as loud as it ever gets.
You guys think it's bad to drive the car with it?
Old 05-24-2007 | 03:02 PM
cincyTT's Avatar
I'm make believe
The i never heard any turbo make that noise.Are you still makeing normal boost and spool?
Old 05-24-2007 | 03:04 PM
cincyTT's Avatar
I'm make believe
You know what, you might want to check the turbo, the blades maybe damaged. A turbo slowing down ususally sounds like a slowing constint hhhiiiiiissssss
joshuo's Avatar
well i don't have a guage to check, but the butt dyno tells me it's the same, and the dealer didn't get any engine codes.
how would i go about to check the turbo?
