Started building sub enclosure
I started building my sub enclosure this weekend. Should be done some time next week. I cut the wood (3/4 MDF), laid it out roughly. Still need to radius corners, assemble, caulk, sand, lay fiberglass, sand, bondo, sand, and paint. I goal is to paint it to match the outside of the car, so it looks like an actual part of the car and not a sub enclosure. No carpet for me!
Putting in 2 JL 8W7 and a JL 500/1 monoblock.
Before I get comments, I know the supports are not even, they are not screwed down yet, only sitting in there for support to hold the top up.
Damn I am soo envious, those are the xact sub and size that I wanted. But I was going to use a Phoenix Gold Titanium 1200 watt mono block. I opted to use Rockford Fosgate T110's. At 350 per JL ack too much. But 2JL 8W7 is gonna make your car sound insane.
Thanks guys! I have to go buy a router tonight or tomorrow, so I can finish this darn thing soon.
Depends are you using an aftermarket head unit? If you are then yes there is a wiring harness for your car. You wouldn't need to use a hi-lo converter.
what about where to tap into when using the stock unit ? sorry i posted in Electronics section but can't get an answer.. I can't figure out where/how to get my line-out converter / high-low converter into !
also.. i love the box man, can't wait for my pics
On topic- Gorgeous box, with some of the best 8in woofers to match. should sound pretty clean when all said and done. Are you planning on upgrading your mids and highs to something of the same caliber as your sub-stage?
Damn there is only one company that makes the wire harness... Let me find out which company makes it and will post.. But here is an easier way to find out.. pretend to make a headunit order from crutchfield.. they will tell you what harness isneeded.. it's the same one from another line of audi, i think the b5,6.. Or you can go into your local stereo shop they should be able to tell you.. Like i said there is only 1 harness.. cost maybe 20 bucks at most.
