Spark Plugs
Old 08-27-2010 | 12:39 PM
kwaskow's Avatar
Default Spark Plugs
Looking over the FAQ page, I see the following options for a stock car. Mine is an 04, 225.
SPARKS PLUGS
OE Plugs: NGK PFR6Q - .032" gap
For Stock Cars - .032" gap:
NGK BKR6E
Autolite 3923
Denso Iridium IK20
Which is best?
Old 08-27-2010 | 02:27 PM
quaTTrophobia's Avatar
SPARKS PLUGS
NGK BKR6E
Autolite 3923
Denso Iridium IK20
Which is best?
PFR6Q is the o.e. NGK spark plug that you will get at the dealer or can get them in an NGK box under stock #6458 (original quipment service part. and is Platinum/Iridium)
BKR6E is NGK plug with a V-cut electrode and a copper core.
if u want Iridium in an NGK (similar to o.e.) its BKR6EIX
if U want Platinum " " " " " " " BKR6EGP
the o.e .plugs are three/four times the price of the copper.
you pays your $$ and takes yer cherce... stay with NGK .
The o.e will last 50- 70 K miles possibly but I would use the plat or irid and change every two years and the coil paks (o.e. only) every 50K. You must carefully gap the plugs.
Old 08-27-2010 | 10:58 PM
jakej's Avatar
Correct. Gap them correct!!!!
Old 08-30-2010 | 10:39 AM
kwaskow's Avatar
So, would you recommend the OE plugs?
Old 08-30-2010 | 08:19 PM
jakej's Avatar
I would just go with whatever is easy to find.
Old 08-30-2010 | 09:35 PM
ilackav8's Avatar
agreed. ive been running autolite platinums with no problems...the NGKs are strangely elusive.
Old 09-03-2010 | 02:37 PM
NorthD's Avatar
Default spark plugs
The best spark plugs on the market are Brisk Racing plugs You have no gapping they sit deeper and they add horsepower to your car.
run colder............ check it out http://briskracing.com
http://whanab.com/
cwedholm1
03-14-2010 12:47 AM
Eric_C
12-13-2009 11:48 PM
hsbertiii
01-19-2008 02:42 PM
domino877
11-28-2007 10:09 PM
aerostatwv
11-22-2007 08:20 PM
