Smokes @ start up
Old 07-25-2007 | 01:15 PM
projlightning's Avatar
Default Smokes @ start up
I have a 2000 180 TT that smokes like a chimney when started up. Looks like how it "smokes" on COLD days....not smokes but you guys know what I mean. It happens in the mornings and/or when I park it for a while and start it up again. After it's warmed up, all is good so I'm not sure what the deal is. The exhaust time is no longer chrome. Oil is good (mobil 1 synthetic)...
Any advice
Old 07-25-2007 | 01:21 PM
bmwtoaudi's Avatar
Default RE: Smokes @ start up
Are you burning oil? - Maybe you have a gasket leak somewhere and your car is burning oil or coolant? - What else is going on?
Old 07-25-2007 | 01:29 PM
225tt's Avatar
What color smoke, blue, white, black? Anything that was on a downpipe or the turbo itself like oil, WD-40, etc...? Where is the smoke comming from? Need more info please.
Old 07-25-2007 | 02:30 PM
White.... Comes out like how it looks on a very cold day...
I did an oil change 1500 miles ago and it's still full. No leaks that I can see when I crawl under there and from above nothing also.
Old 07-25-2007 | 02:47 PM
225tt's Avatar
It comes out the exhaust? Have you checked your coolant, everything else runs fine?
Old 07-25-2007 | 02:52 PM
coolant level is fine, runs well...
Yes out the back
Old 07-25-2007 | 02:54 PM
cincyTT's Avatar
I'm make believe
sounds like he might have some condensation built up in there or is pig rich on start ups
Old 07-25-2007 | 04:36 PM
anymore feedback?
Old 07-25-2007 | 04:48 PM
techbod's Avatar
it could be an oil leak into a seal on the exhaust most common fault is leaking rocker cover gasket on to the exhaust down pipe and being sucked into the exhaust hence the smoke
Old 07-25-2007 | 05:55 PM
Mechanic buddy of mine said ALMOST the same thing...
I guess I have to find a certified tech in my area to take a closer look.
Thank you all for the replies
yves.axel
11-30-2011 12:30 PM
01ttroadster99
05-24-2011 04:27 PM
aamele8
02-13-2011 02:56 PM
aamele8
02-10-2011 12:02 AM
audinovice0819
02-18-2010 09:03 AM
