Slow Rising Convertible Top
Hello All
I have an '02 roadster that I bought last spring. All last summer, my top raised and lowered smoothly and without any issue.Now, after sitting up for the winter, I find that the top takes time to start lowering, makes some grinding sounds and lowers in a jerky motion like the motor is struggling to pull it down. I have the same issue when the top goes up again.
I talked to another TT roadster owner and he suggested that thelift motormay need an infusion of fresh hydraulic fluid...does any one know if this is true and if so, where is the lift motor located in the car? I don't access to a tech manual.
Also, I wash my car regularly including the top, I hope water isn't getting trapped in the lift gear and rusting it all together?
Thank you for any suggestions...
John
John
RE: Slow Rising Convertible Top
ORIGINAL: qwikslvr
ORIGINAL: qwikslvr
John
John
Should be using ragtop cleaner or something.
I do use a wand, but I stand a fair distance away to keep the pressure down...just enough to wash the dust and crap off. I don't blast the water directly onto the fabric either. I've never had any water soak through. I'm not too keen on using a cleaner because I'm afraid the solvents in the cleaner may cause the fabric to fade or break down prematurely.
The top is in immaculate shape with no sun fading at all so washing with light soap and water with a good rinse seems to work for me...
