View Poll Results: A poll
Do it now, rather then 10k miles later
50.00%
Don't worry, they never fail at 50K miles
50.00%
Voters: 10. You may not vote on this poll
should I do the timing belt now?
Old 09-30-2007 | 07:25 PM
andrei's Avatar
Default should I do the timing belt now?
ok... my car has 51K miles.
It runs good, but it really tends to overheat when I am stopped at a red light, even when it's not hot outside. Any good(new) engine doesn't do that, not even at 115 F... That is the main reason why I am asking this... I'm not scared of the broken belt teethas much asI am worried about my engine heating up...
Also when the engine is running, even at night, the center console( parts closest to the tranny)heats up really bad, like you can't hold on to the silver arms with black knee pads on them, that's how hot they get... Thanks for reading...
Old 09-30-2007 | 07:41 PM
randomloginname's Avatar
Default RE: should I do the timing belt now?
You might have posted this elsewhere, but have you done things like replace the coolant sensor, check the fuses (driver side and on top o battery) and check to see if your fans both run after a good drive? If you believe you may have a faulty thermostat or water pump, doing the timing belt sooner is even better (obviously doing the things I just mentioned at the same time). Yes 10k miles on the earlier side, but think about how you wont have to do it again for at least another 50-60. Not only that, if everything is running hot, components are going to fail earlier, and you obviously know how much cheaper the tb service is then the I ruined my engine from ahving a busted tb service is. go for it, but check those other things too if you havent already.
Old 10-01-2007 | 04:40 AM
meanse's Avatar
andrei i am having the exact same problems you are talking about, my car has a few more miles than yours, but i am doing the timing belt service this weekend and ill let you know how it turns out.
Old 10-01-2007 | 07:16 AM
andrei's Avatar
Iappreciate that... and if you are around to kinda tell me what write upyou used...that would be great... does your car alsohave a louder noise level at the passenger side wheel well then at the driver's side wheel?
thank you for the answers guys...
Old 10-01-2007 | 05:22 PM
alan93's Avatar
I would say not enough info.
What's the inservice date on your car?
Did it go into use in 2000?
If so that's 7 years ofdrivingin which case you would be way over due IMO based on what Ihave read on this which is a lot.
Mines about at thesame miles but its a2002 but didn't go into service until mid 2003 so mine isn't as desparate yet.
Old 10-01-2007 | 05:25 PM
quattro411's Avatar
sounds like you have some serious overheating issues, ive never herd of the triangles getting too hot
Audiguruforyou
09-20-2011 02:31 AM
vtraudt
04-01-2011 10:40 AM
TheBat
06-20-2008 02:14 PM
