Revoed and dynoed
RE: Revoed and dynoed
You have a 180 or a 225?
I put down 190FWHP stock with avery weak, slipping clutch on a dynojet dyno.
(225Q with the fuse pulled to run FWD on the Dyno)
So, for a 225 I'd say that # is low.
For a 180 I'd say it depends on the Dyno.
You should have gotten a baseline on the same dyno, that's the only real way to compare results.
That's ok then... either one works fine.
HP Still Seems low to me, but the torque sounds good which is odd?
How's your clutch?
How's your clutch?
ORIGINAL: porc933
I know they pulled a clip off the haldex it's self. As far as a fuse in the car no they didn't.
Clutch is good(knock on wood). I can't seem to understand it either. The torque number is great, I think that maybe it's just the dyno. But notgetting a baseline was the first mistake on my part and the shops.
