Received my gauge today.
I ordered the sport comp II boost/vacuum gauge from egauge.com
What's up with these connecters?
the T tube > rubber tube > nylon hose? Will this thing pops?? Doesn't seem secure at all..
Also this hose connect to the back of gauge...
Also is it all gauge package dont come with electric wire connector?
Thanks for your help! (sorry for the bad cellphone image~)
gy
gy
RE: Received my gauge today.
I have always used AM gauges, they aren't as fancy as some such as defi but they get the job done. I myself have always ditched the hard nylon line and use thick walled vacuum hose. I find that the nylon tends to kink too easy and get pinched. As far as electrical connections go...isn't that what the spades are for? The AM's that I have used come with a lightbulb with pig tails ready to splice. Also note if you do choose to replace the nylon line you can ditch the boot reducer and attach it directly to the T. You would also ditch the compression bead and hex nut. Just lube up the hose and stretch it over the hex nut with thethreaded nipple.
Oh yeah dont forget the thread tape and zip tie your connections!
Yes we know....thats why I stated:
"As far as electrical connections go...isn't that what the spades are for?"
You can pick a pack up of female spade connectors for a couple bux at the parts store. Didn't the gauge come with a small roll of wire? Connect to the dimmer wire on the backside of the light switch (blue/grey wire) and ground out on the grounding lug behind the lower dash assembly. Easily spotted...alll brown wires going to it.
