Reason I threw a code!
Old 12-06-2007 | 06:57 PM
moeron7's Avatar
Default Reason I threw a code!
So the other day I got a CEL and pulled p1296. I check under the hood and my filter had came off my MAF. Should I be worried that something could have been sucked in there or would I have know right away?
Old 12-06-2007 | 09:54 PM
diehlryan's Avatar
Default RE: Reason I threw a code!
P1296 Is a cooling system malfunction. Keep an eye on your engine temp and see if its reaching 90-93c. If you dont know how to use your HVAC to check this out do a search and get on it. You may notice youre staying in the 70-80ish range and that points to a thermostat stuck open not allowing your engine to warm up.
Old 12-06-2007 | 10:00 PM
cincyTT's Avatar
I'm make believe
the intake filterfalling off wouldnt set off a code anyways.
Old 12-06-2007 | 11:23 PM
moeron7's Avatar
ORIGINAL: diehlryan
Damn, I dont know how to do that, i remember reading about it but i guess i'm gonna have to do a little research. Is the thermostat an easy replacement, i think i've seen an install done before. Anybody here replace one?
Old 12-07-2007 | 10:24 AM
moeron7's Avatar
Ok I found the directions with the HVAC and the hottest my car got to was 71 degrees. What do I need to do next?
Old 12-07-2007 | 10:29 AM
diehlryan's Avatar
ORIGINAL: moeron7
replace your thermostat.
Old 12-07-2007 | 10:30 AM
moeron7's Avatar
Damn! You think its a DIY job?
Old 12-07-2007 | 10:36 AM
diehlryan's Avatar
Thermostat replacement DIY.
I think you should be able to handle this on your own.
Old 12-07-2007 | 10:42 AM
moeron7's Avatar
ORIGINAL: diehlryan
Man i've been looking for that since last night. Thanks Ryan
You think this might be the reason my secondary air pump isnt turning on in the morning as well?
Old 12-07-2007 | 10:47 AM
diehlryan's Avatar
ORIGINAL: moeron7
Nope. I think thats either a shot airpump or electrical issue. I'd check and see if the airpump runs on its own fuse and start there.
