Rear Suspension Alignment Question
I have coilovers and am debating taking out the rear perches to lower the car to exactly where I want it. That being said, I am also trying to correct rear camber and toe. I am curious to see which option would be a better long term fix...
1) New rear adjustable control arms ($300)
http://www.gocpt.com/products/1/controlarms.php
2) Rear Half Kmac Kit ($175 or so)
~Any input or experiences?
Do I need to do top and bottom control arms, or will one set work?
Or is this one of those things where I have to trial and error the results? Also if I get one set, should they go on top or bottom?
hrrrrmmmmmmmm, more questions than answers now...
My car is lowered about 1-1/2" with Full K-Mac (both upper and lower) and I am dialed in at -1.8 on both sides.
If you are lowering more than 1-1/4" you'll max out the half kit or lower arms. The only way to do it right is have adjustability top and bottom. You can do the adjustable arms on the bottom and K-macs on the top or either type all the way around.
