Rear rotor question.
Do you guys have any tips for removing the rear rotors. They are stuck on there pretty good. I sprayed some wd40 and let it sit for awhile then hit it with a hammer but no luck. I'm going to stopped and get a rubber mallet on the way home and try again but I just wanted to see if anyone has any tips first. Thanks.
thanks. i did take the screw out but the rotor is still on there pretty good. i think where i may be going wrong is that i didn't take the caliper carrier off so i am going to try that tonight and then beat it with a mallet if that doesn't work...
Remove the calipers, then on the rotor there is 1 screw.. You need to remove that. Then use a hammer and hit the rotors hard. Hit it on the face of the rotor towards the edge. It will come loose. I just did mines 2 weeks ago.
ok, i finally just loaded it up with spray and let it sit all night. first thing this morning i went out and hit it once really hard with a mallet and it fell right off, right onto my foot actually. thanks for all the help.
