program new key
program new key
I just got my new key and found a place to cut the key and only be 25 dollars to cut, is there a way to program the remote myself rather than bringing it to the stealer?
The key was from ebay so has no programming in it.
RE: program new key
the chip in the key has to be programmed into the system ( full working VAG can do it ) it has to be licensed to make it fully work though, other software and interfaces do the same
edit: you can integrate 8 remotes and keys but it needs proper diagnostic gear to do it ( the key programming is the point ) because its chip based and the remote plip/button isn't
