Problem with TT
RE: Problem with TT
My MAF is working up, and my ABS/TRACTION light is on as well.
I'm going to be cleaning mine tonight as well...But I have a feeling thats a sensor issue as well.
Can auto zone run the codes to see what sensor it is?
RE: Problem with TT
The triangle with the circle around it is constantly lit as though I hit my ASR button, and my ABS light is on. However they keep turning on and off depending on the day..Its REALLY annoying. - It completely turns traction controll off...Mind you I dont care because I drive with it off mostly anyways.
Now my brakes make a little noise...so im going to be replacing them this weekend.
My check engine light is on, codes pulled shows o2 sensor and the MAF sensor acting up.
I'm going to clean my MAF tonight....if that doesn't fix the issue im going to buy a O2 sensor online.
#19
RE: Problem with TT
I had a probelm with random ESP/ABS lights a couple of months ago. Some kind soul on this forum (please take credit) informed me to check my battery. I'm told the TT electronicsare very sensitive to voltage. My battery was reading 12.25 volts (Autozone load tested and passed it) and I had problems. Replaced it with a new battery with 12.5 minimum and have not had a problem since. I suggest check to ensure you are getting 12.5 min...it's worth a shot
