problem at cold start
Old 02-20-2008 | 02:52 PM
TT_GUY's Avatar
Default problem at cold start
every morning since the forge 004 install car would bog for 1 second at start up then every thing would be normal.. Is this something I should look into? I can't install the dv back on cause I cut that hose to fit the bov. Any suggestions
Old 02-20-2008 | 02:55 PM
TT_GUY's Avatar
Default RE: problem at cold start
i did order a new 90 degree samco 25mm silicone hose cause the stock modified hose looked like its not flowing air out enough
Old 02-21-2008 | 10:15 AM
patty AT forge's Avatar
What spring do you have in the valve?
And did you plug up the recirc port on the turbo inlet pipe?
Old 02-21-2008 | 11:26 PM
TT_GUY's Avatar
i purchased the bov without a spring kit so i believe its the stock spring...yep i plugged up the intake pipe and also installed the samco hose for the bov....i have no idea if itt has anythign to do with the ECU readings...i never did reset the ecu after install....am i suppose to?
Tarantoga
07-22-2015 04:44 PM
J-mo
01-06-2013 08:47 PM
josearey
12-09-2011 04:05 PM
02A418T
11-03-2006 03:40 AM
LuckyCharmsUXZ
08-17-2006 04:21 PM
