Is possible to survive snapped timing belt without damage??
Old 10-08-2007, 09:07 PM
pitrman's Avatar
Default Is possible to survive snapped timing belt without damage??
yea, it happened. But I was doing just like 15-20 mph in 2nd gear. sudenly the engine stopped. I didnot hear absolutelly nothing. So I start to check out the fuses... but later on my mechanic told me that it was a broken timing belt. He will find it out later this week, but I just wanna know if somebody has the same experience..
audi tt quattro 2001 225hp
thanks
Old 10-08-2007, 09:09 PM
rayveedub's Avatar
Default RE: Is possible to survive snapped timing belt without damage??
negative. not possible. not even at idle. that really suck man.
Old 10-08-2007, 09:10 PM
theTTkid's Avatar
i think your screwed... just what i think
Old 10-08-2007, 09:11 PM
225tt's Avatar
Nope need to take it in to get work done. Why did it break?
Old 10-08-2007, 09:12 PM
rayveedub's Avatar
good news is you might have been going slow enough to not damage the guides. you are allowed a .3 crack before being out of spec. if you did crack the guides the head will have to be machined.
Old 10-08-2007, 09:13 PM
eliTTe's Avatar
a local guy with a TT here had his break at idle and didn't damage anything, they still had to tear it apart to check but everything was ok. he is on this forum, name issmokn951 or something like that.
Old 10-08-2007, 09:14 PM
cincyTT's Avatar
I'm make believe
the pistons moving is far to much for the valves. How many rpms is more important that speed. If your lucky the pistons arent to bad. You mainly need new valves and smooth out the pistons if they have damage, again rpm dependant
Old 10-08-2007, 09:15 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: eliTTe
he really should so a compression test or leak down test. Im sure it may appear to be no damage, but the valves may still be bent.
Old 10-08-2007, 09:18 PM
eliTTe's Avatar
I thought the intake had 12 valves and the exhaust had 8 [>:].... or atleast my car does
Old 10-08-2007, 09:21 PM
cincyTT's Avatar
I'm make believe
It does, i didnt reread before posting again
Quick Reply: Is possible to survive snapped timing belt without damage??
