popping sound backing out of driveway
geez, that might be overkill. heh.
It may not though, depending on your tools. Fought pretty hard to get the strut free from the carrier when I did my wheel bearing, didn't have my stretcher tool then. Had I removed the strut and carrier, and THEN tried to separate them, I probably would have had more room with the pry bar. live and learn.
probably not the bearings. bearings 'growl', and if they're the front ones, which are the ones more likely to go bad, you'll feel a slight vibration in the steering wheel usually.
Look to CV's, or strut tower bearings first.
^ i can confirm the strut tower bearings.
mine have knocked on rare occassions with the new strut tower bearings in. maybe the break in period? well i havent heard it knock in awhile... gonna do the sway bar bushings, see if that helps any
#19
all of the fixes to correct this so far, have been under warranty. I think replacing the subframe has to help. They have all ready replaced strut bearings/bushings, lower sway bar, still fukin pops! Should get it done this week. I'll keep you guys posted on what happens.
