Pondering k04-20 upgrade
#21
RE: Pondering k04-20 upgrade
yeah i wonder about that piece too. when i took it off (while doing the clutch) it doesnt really seem like it needs to be there if you have a FMIC people say its a structual piece but i dont really see how.
#23
i dont have the FMIC yet so i had to put it back in for the 2 side mounts but i'll be doing more research and if i dont need that piece then i'll leave it out when i do the fmic
#25
can you see how much you can get this part for? if your looking at the front, the left inner side wall( infront of tire, behind intercooler) it looks like its slotted, this prevents some heat soak and is a functional piece. i just need that side piece. its in the wheel well. Please and thank you
#26
I will as soon as I get the opportunity. Yesterday was just drug testing and a backround check. I dont actually start working until next week. Didnt get to ask them anything bout my car either.
#27
I think I should add: I thought of a way to redesign the 6x8" fogger rail to work with the stock sidemount. I reshaped it from a 2 dimensional rectangular rail to a 3 dimensional cradle that will spray the sides and front of the core. With a 90 degree CCW turn it should fit and work perfectly now. Also simplified mounting to a couple pieces of wire coat hanger and some metal zip strips.
pics:
[IMG]local://upfiles/19618/0FB2DC03ED254908BC1F45720743A7F5.jpg[/IMG]
[IMG]local://upfiles/19618/8761DF4F1E2C4CB4ACED480B9F7F601C.jpg[/IMG]
pics:
#28
Got a 2nd opinion on the cross-charge pipe on the 180 and its strutural value today. None.
Which verifies what I thought. This means that its coming out, uneeded weight (a good 15-20lbs).
#30
Or something better, yes. Especially when you consider the chances of leaving the boost levels stock. I dont think one small SM intercooler is going to handle the bigger turbo plus elevated boost. I think Audi would agree with me, as thats why the 225 comes with the dual coolers.
I wouldnt say you need to replicate the 225 setup exactly, but you need to match or exceed the efficiency of it.
