please help
Old 08-26-2007 | 12:33 AM
cincyTT's Avatar
I'm make believe
Default RE: please help
Your gonna wanna look at the engine code also. You want a BEA not a AMU
They code can be found on the head here
Old 08-26-2007 | 02:17 AM
M FLYTT's Avatar
oh sh*t... now i know that isnt your car cincy, is it... you should have a ATC engine... but that sure does look nice...
Old 08-26-2007 | 02:05 PM
cincyTT's Avatar
I'm make believe
That is not my car. That was stolen from vortex. I wish i had a AEB head , not sure about the 35r though
Old 08-26-2007 | 02:56 PM
M FLYTT's Avatar
is BEA and AEB the same thing?
and whats so special about them?
Old 08-26-2007 | 03:22 PM
cincyTT's Avatar
I'm make believe
AEB is the 98-99 a4/passat head. It is the only big port ever sold in the US. Everything else a4/passat/gti/jetta/TT has a small port head.
The large port is wider and flows far more air than a small port head. You can port a small port head to fit large port intake manifolds, but you cant make the flow the same.
Old 08-26-2007 | 04:58 PM
Charlie TT's Avatar
so if i was looking at att i should look for the AEB code near the head?
Old 08-26-2007 | 05:08 PM
PCBOI808@HOTMAIL.COM's Avatar
could you switch the head out
  #18
Old 08-26-2007 | 05:13 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: Charlie TT
You are looking for it to say BEA and not AMU like i posted earlier since i bet some 03's are still AMU's
  #19
Old 08-26-2007 | 05:15 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: PCBOI808@HOTMAIL.COM
You can, but you have to do some other things beside just swapping heads, but many have done it. The only problem is that the cost for the AEBhead is now around $1k for a used head and only a few hundred for a small port. So you can build a small port and even port it for about the cost of a AEB head alone
  #20
Old 08-26-2007 | 05:41 PM
Charlie TT's Avatar
amu head bad or its just small so it would be better to find a BEA
