P1136 cel back
Old 03-28-2007 | 11:41 AM
sound227's Avatar
Default P1136 cel back
My car threw the p1136, p1128, and p0102 about 3 months ago....I replaced the MAF and everything has been fine since. I even checked last month when I was at auto zone to see if any codes were stored without tripping a cel and nothing. Yesterday out of nowhere I felt it loose power while driving, and a few minutes later the cel came on with a 1136 code yet again. Any idea where to look now. Also, where is the best place to get a vag-com set up from. Thanks.
Old 03-28-2007 | 04:34 PM
XCLR8TT's Avatar
Default RE: P1136 cel back
It's quite possible that you have a vacuum leak. You'll likely need to do a pressure test in order to locate it.
The best place to get VAG-COM is from Ross-Tech.com. Many people get the cheap cable off of ebay, but you are better off in the long run by spending the extra $100 to get the real thing from Ross-tech.
Old 03-28-2007 | 04:57 PM
sound227's Avatar
So what actually comes in the VAG-COM set up, what do I need to make it work. Sorry for my ignorance, I had a data logger on my talon but it was just my palm pilot and a modified cable. I don't plan on doing any mods to my tt, i just ned the vag to see where these codes are being generated from. Also, it says they are for use with a PC. I have a Mac Powerbook G4, is the software only for a PC or is it MAC compatible?
Old 03-28-2007 | 05:30 PM
rayveedub's Avatar
need a o2 sensor.
thebeav
01-11-2011 11:09 PM
sivak.puvvula
07-15-2010 12:11 PM
Audacity
05-18-2009 01:19 PM
sound227
12-13-2007 03:34 AM
sound227
07-17-2007 08:45 PM
