OSIR Clear Corners Install Question
I am currently installing the clear corners from OSIR. I am at the point in which I am ready to bake the headlights following these directions:
http://public.fotki.com/thorenpc/car...design_smoked/
My question is, before I bake my headlights at 175 degrees for 10 minutes, do I need to remove as much hardware from the headlights as possible? (bulbs, HID modules, etc) The directions do not say and all of the other directions I have found that show how to bake your headlights do not tell either. I don't really want to remove the hardware if I do notneed to.
RE: OSIR Clear Corners Install Question
No. I used the heat gun as well..I always thought the whole oven thing was retarded why cook the ballast and all the electronics in the headlight? Many have done the oven method and have had no problems. Do as you will
