Oh My God.. My Alternator died AGAIN!@#%@!
Old 11-18-2007 | 11:35 PM
neur0tic's Avatar
Default Oh My God.. My Alternator died AGAIN!@#%@!
I am so ready to drive this car off a cliff right now.
I love this car to death but i just CANNOT afford to replace this alternator every two weeks.
-sigh-
does anyone here know what would cause this? the first symptoms seem to be the battery light coming on... loss of the tach and speedometer gauges... ABS light... along with the trunk open light always coming on and the trunk unlocking.
Old 11-18-2007 | 11:38 PM
cincyTT's Avatar
I'm make believe
Default RE: Oh My God.. My Alternator died AGAIN!@#%@!
You didnt just buy a cheap used/rebuilt part did you?
Old 11-18-2007 | 11:46 PM
eliTTe's Avatar
ORIGINAL: cincyTT
I did and mine is still fine!
Old 11-18-2007 | 11:51 PM
neur0tic's Avatar
I bought a rebuilt alternator, yes.
I dont even know where I COULD buy a new one... everywhere I've looked only sells rebuilt ones.
Hell, almost all alternators are rebuilt
Here's the Vagcom Fault readout:
Monday,19,November,2007,12:43:08:19358
VAG-COM Version: Release 704.1
Data version: 20071016
Chassis Type: 8N - Audi TT
Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77
VIN: TRUWT28N911021041
Address 01: Engine Labels: 8N0-906-018.LBL
Part No: 8N0 906 018 K
Component: 1.8L R4/5VT G02 0003
Coding: 06710
Shop #: WSC 01236
TRUWT28N911021041 AUZ5Z0Y9303038
6 Faults Found:
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-10 - - - Intermittent
17963 - Charge Pressure: Maximum Limit Exceeded
P1555 - 35-10 - - - Intermittent
16946 - System Voltage: Too Low
P0562 - 35-10 - - - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
17840 - Secondary Air Injection Solenoid Valve (N112): Open Circuit
P1432 - 35-10 - - - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8N0-907-379.LBL
Part No: 8N0 907 379 E
Component: ESP 20 CAN V005
Coding: 18446
Shop #: WSC 01236
No fault code found.
Address 08: Auto HVAC Labels: None
Part No: 8N0 820 043 A
Component: TT-KLIMAVOLLAUTOMAT D03
Coding: 00140
Shop #: WSC 01236
1 Fault Found:
01206 - Signal for Duration of Ignition Off Time
27-10 - Implausible Signal - Intermittent
Address 15: Airbags Labels: None
Part No: 8N8 909 601
Component: Airbag Front+Seite 1008
Coding: 10103
Shop #: WSC 01236
1 Fault Found:
01218 - Side Airbag Igniter; Passenger Side (N200)
32-10 - Resistance too High - Intermittent
Address 17: Instruments Labels: 8Nx-920-xxx-17.LBL
Part No: 8N1 920 930 J
Component: KOMBI+WEGFAHRS. M73 D56
Coding: 02244
Shop #: WSC 25168
1 Fault Found:
00668 - Supply Voltage Terminal 30
53-10 - Supply Voltage Too Low - Intermittent
Address 22: AWD Labels: 02D-900-554.LBL
Part No: 02D 900 554 D
Component: HALDEX LSC ECC 0011
1 Fault Found:
00526 - Brake Light Switch-F
Address 35: Centr. Locks Labels: None
Part No: 8N8 962 267 A
Component: Central Lock/Alarm D04
Coding: 15948
Shop #: WSC 01236
12 Faults Found:
01366 - Opened Due to Crash Signal
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
07-10 - Signal too Low - Intermittent
01616 - Signal Wire to Interior Monitor
36-10 - Open Circuit - Intermittent
00955 - Key 1
09-10 - Adaptation Limit Surpassed - Intermittent
01570 - Turn-Off Delay; Terminal 15
29-10 - Short to Ground - Intermittent
01618 - Automatic Convertible Top Valve 2 (N272)
29-00 - Short to Ground
01109 - Hydraulic Pump Relay (J321)
01586 - Locking Cylinder Contact Switch; Passenger Side (F242); Close
01585 - Locking Cylinder Contact Switch; Passenger Side (F242); Open
Address 45: Inter. Monitor Labels: None
Part No: 8N8 951 177
Component: Innenraumueberw. D09
Coding: 00001
Shop #: WSC 00000
1 Fault Found:
01463 - Alarm triggered by Sensor for anti-theft alarm System
35-00 - -
Address 55: Xenon Range Labels: 4B0-907-357-AUT.LBL
Part No: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00010
Shop #: WSC 01236
End --------------------------------------------------------------------------------------------------
Old 11-19-2007 | 12:45 AM
ouTTie914's Avatar
Do you think, just maybe... all of you audio equipment is putting a strain on the alternator?
Old 11-19-2007 | 12:47 AM
themysteryman83's Avatar
I think outtie might be on to something...
Old 11-19-2007 | 02:31 AM
rayveedub's Avatar
what brand did you buy? yes mostly all alternators are remans but duralast isnt as good as bosch.
Old 11-19-2007 | 07:00 AM
neur0tic's Avatar
Its a stock alternator.
...and no, not the audio. All the audio equipment has been disconnected at the source (the power cable on the battery is disconnected) since before the last incident.
The audio was my first check when it acted up the first time and I disconnected all power going to it and removed it all from the car before i took it to the shop for the first alternator issue. For two reasons actually: to eliminated it as a possible cause... and to prevent the $10,000 in equipment from being stolen while in the custody of the auto repair facility.
So no... it isn't the audio.
The alternator was replaced a week ago and I haven't gotten the time to put all the audio stuff back in yet. I guess its a good thing though since I'd just be removing it again now to put it back in the shop.
the alternator I bought to replace it was from a 2001 TT 180 that was totalled. It's bosche.
Should I try throwing a new alternator in it?
Alternators are pretty simple machines. Too much power draw on an alternator will almost never cause it to go bad anyway. Too little power draw possibly could (wet stack). what all could you possibly do to kill one other than getting oil all in it? I have a feeling that I just installed a bad alternator.
I bought the alternator used from an Audi TT Part-out and when it arrived, the pulley was different from mine. They did not have the clutch tool to change the pulley... so he pulled the alternator apart at the case half and install the whole front half (the half with the pulley) from my old one... on the back half of the new one. This worked for one week, now the problem is back. Do you think something in the front half (the part from my old alternator) was causing the back half to go bad and thus destroying the new back half like it did the old one?
Old 11-19-2007 | 05:15 PM
.clipse's Avatar
SoCal Crew Member
youve been having problems ever since youve done your w/m injection
Old 11-19-2007 | 05:38 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: .clipse
Is that true? You could have a bad ground or something else that is draining your power like mad. Check all of your connections and look for any possible problems. You should have someone else look them over also
