Offset Question
Old 09-29-2008 | 01:34 AM
HartsvilleTT's Avatar
Default Offset Question
So I'm a newbie here and I've been doing some searching on here and I can't get the offset calc. to work. Anyway, I was wondering if I were to buy 17x7.5 rims with a +40 offset, what size spacers if any would I use? Suggestions?
Thanks!
Old 09-29-2008 | 02:00 AM
cincyTT's Avatar
I'm make believe
how can you not get the calc to work? You just install the width 7.5, offset 40 and 0 for spacers and it will tell you what mm you are inside or outside the fender. If you are inside by XXmm, you get the closest spacers you can to keep you inside the fender, they come in 5mm incroments.
Old 09-29-2008 | 11:27 AM
.clipse's Avatar
SoCal Crew Member
under assumption, ~ 30mm spacers to be somewhat flush.
Old 09-29-2008 | 01:46 PM
Ok thanks. Its not that I couldn't work the calc. I couldn't find a link that worked. Sorry for being vague.
Old 09-29-2008 | 04:06 PM
.clipse's Avatar
SoCal Crew Member
Syfer23
03-03-2015 01:51 PM
yellow_submarine
07-24-2011 12:55 AM
B7_A4
03-21-2010 10:20 PM
dms
06-13-2006 06:03 PM
headshok2002
07-16-2005 03:29 AM
Quick Reply: Offset Question
