Offset Calculator
Old 04-19-2007 | 03:39 PM
Indiepunk's Avatar
Default Offset Calculator
I was looking at an offset calculator and was wondering what the field meem was? In the equation (below) as long as the last field is a positive number, the rims will fit right?
[IMG]local://upfiles/30623/4279259350094CD8A5659D9ACBFCAFF6.jpg[/IMG]
Old 04-19-2007 | 06:30 PM
cincyTT's Avatar
I'm make believe
Default RE: Offset Calculator
meem is the person they used as an example, if you have a awd and those specs if will be flush with fender.
You will want to enter the wheels specs, width and offset and if you have spacers or not. You will want flush with fender or inside fender on the far right.
Old 04-19-2007 | 06:50 PM
Indiepunk's Avatar
I found someone that has rims that specs are above in the offset calculator picture. The9.5 back rims leave 9mm free space. I was looking on ebay and found 5mm adapters but am not sure ifthey will work. That item is here:
http://cgi.ebay.com/ebaymotors/Ichib...spagenameZWDVW
The rims I am looking at are 114.3. I looked at ECS Tuning but only found 5x100 to 5x120 adapters.
Old 04-19-2007 | 07:04 PM
cincyTT's Avatar
I'm make believe
Those are just spacers on ebay. Adapters are probably going to be 20-25mm and not 5-10mm.
Old 04-19-2007 | 07:21 PM
Indiepunk's Avatar
There goes that option. $600 for staggered 19" rims would have been sweet. Too bad they were 114.3 and the backs 9.5".
dan1979
02-10-2024 01:21 PM
jorgecol77
02-19-2013 11:42 AM
capn
11-14-2012 06:34 PM
vivithemage
B7 Models
09-22-2008 11:57 PM
ImTheDevil
11-08-2006 12:16 PM
