O2 Spacer
What did you do? I have done it using two spark plug anti-foulers, it has worked for several years without problem.
Have you Vag-Com'd the CEL to see just what the error is?
FYI, when you clear a CEL it takes between 60-80 miles for it to cycle through. If you didn't clear the problem initially, the CEL will return.
i got the MCPI O2 spacer, i had the cel read and deleted after i got it installed, then boom it came back on.
I will inquire about the stage two software, about to get a duel exhaust set up anyways
thanks all.
thanks all.
