NOS kit safe on TT?
Old 09-11-2007 | 10:37 PM
outinfront's Avatar
Default NOS kit safe on TT?
How safe do you guys think a professionally installed NOS kit is for the TT...I wonder if the engine will take it?
Old 09-11-2007 | 10:41 PM
moeron7's Avatar
Default RE: NOS kit safe on TT?
ooantipostoo is running one.
Old 09-11-2007 | 10:55 PM
cincyTT's Avatar
I'm make believe
more than he should, but is running one
a 75wet shot is the most i would say to run. But with a ATC/AMU/BEA block the 100wet shot seems to be ok. And this is of course not injected until ~4k range
Old 09-11-2007 | 11:11 PM
outinfront's Avatar
Is this all without internal engine work to prep it for NOS?
Old 09-11-2007 | 11:29 PM
cincyTT's Avatar
I'm make believe
Stock internals, just add a fuel pump and your good to go. I would atleast have a chip first
Old 09-12-2007 | 12:36 AM
PCBOI808@HOTMAIL.COM's Avatar
did he have to make his kit?what brand?[&:]
Old 09-12-2007 | 12:41 AM
cincyTT's Avatar
I'm make believe
he is using the NX drive-by-wire kit
Old 09-12-2007 | 12:47 AM
venmousracer's Avatar
CincyTT what are the internals of a stock 225 TT????
What would be required to do a safe shot? And how big???? and any tuning???
Old 09-12-2007 | 01:11 AM
ive never had n2o before whats it like.is it close to driving a tt for the first time
Old 09-12-2007 | 01:25 AM
cincyTT's Avatar
I'm make believe
ORIGINAL: venmousracer
well there are pistons and rods... same as most cars [8D]
If you run a 50-75 wet or direct shot you should be fine. A vag cable and lemminwinks are a plus so you can turn down the timing a couple degrees for added safety. And finally you really need to inject it in the very late 3k early 4k range.
