Noob question on pedal placement
#21
RE: Noob question on pedal placement
ok, just got back from a drive and when i touch the brake the gas pedel does not work in my 2000. BUT...If i was in nuetral the car would rev up but not in gear. Steve, i bet you should still be able to do it in stock mode because that wouldnt take you car back to 100% stock, just maps. Say if you have a cat delete file, you would still not get a cel for not cat. So i assume the heel-toe would still work also.
#22
You might be right Cincy... but I'll check anyway. I know the chip also removes the Rev and Speed limiters and since I only use the stock mode when I take it in for smog check, I never notice any of those other things. Supposedly the "stock mode" is supposed to be a copy of the stock chip before they removed it to install the new one, but that's only my fuzzy "old man" recollection from 3 years ago.
#23
ORIGINAL: XCLR8TT
#24
Okay.. it's not gone, but I've had it well into the redline at the track and never had it kill the fuel. So it's up there high enough that I never hit it anymore. I know.. some are going to say... "Why not shift, you are out of the power band" The reason for that is, there are quite a few spots on the track where you are 100 yards or so from a braking zone and a corner, so upshifting and then downshifting again takes more away than letting it run up into the redline for a few seconds.
