No AM reception
Old 06-11-2008, 07:03 PM
Neiman45's Avatar
Default No AM reception
Hi gang. I have not been able to get any AM reception since I purchased the car in April. FM is crystal clear. What is causing this? Has anyone had experience with this and if so, did buying an aftermarket antenna help?
Old 06-11-2008, 07:38 PM
Mac_17's Avatar
Default RE: No AM reception
I have the same problem. Maybe someone knows. Do you have an aftermarket radio?
Old 06-11-2008, 07:46 PM
Neiman45's Avatar
No. Stock Bose Concert...
Old 06-11-2008, 07:54 PM
achTTung's Avatar
I can't say I've EVER tuned the car to AM. If I need some extra ambiance in the car, I just wind up the polyphone in the back.... ; )
I really thought I knew the answer to this... but I can't remember what the deal is with the AM antenna. I DID know, its just not coming to mind tonight. First thing I'd do is check whatever connections you can.
Old 06-11-2008, 07:56 PM
jakej's Avatar
The window tint reduces am reception, fm is fine though. I would guess an aftermarket antenna would fix it, since the metal in the tint would no longer be an issue.
Old 06-11-2008, 08:37 PM
achTTung's Avatar
Maybe that's what I was thinking.... if the lines on your rear window are scratched thru, then your antenna may possibly be cut off from the system. Hows the rear defrost work?
Old 06-11-2008, 08:38 PM
achTTung's Avatar
BTW, what rims are those in the pic that you just replaced? ; )
Old 06-11-2008, 08:46 PM
Neiman45's Avatar
Not real familiar with the wheels. They say "NS Racing" and are 17s. I think they are pretty cheap. I suspect the cheapness as the tires are "Spectrum", never heard of em'. The glass is fine but the tint may be a bit dark...maybe that's the prob.
Old 06-11-2008, 09:14 PM
jakej's Avatar
The lines don't need to be cut. The reception well be reduced with tint regardless.
Old 06-11-2008, 09:53 PM
achTTung's Avatar
thought that was only w/ metallic tint.
Quick Reply: No AM reception
