Next Project - Rear Sway Bar
OK. I'm convienced. I want to upgrade my rear sway bar. I've done some install research. It looks pretty straight forward. Has anyone come across any install issues I need to know, or watch for?
What is the best bar? Neuspeed 19mm or the H&R 21mm Adjustable Rear Sway Bar. Thanks.
RE: Next Project - Rear Sway Bar
even though i havent done it, im pretty sure its a very easy 30-60minute job.... both of those will leave your car at about neutral so its just up to you based on price or brand or however you make your decision
I would go with the H&R 21mm Rear sway bar. It comes with lined bushings which are maintanance free whereas the Neuspeed bushings will have to be lubed once in a while to avoid
creaking and noises.
i have the h&r 21mm on my quattroand love it. it was a very easy install (about 30min. total) and made a huge difference- my girlfried even noticed... the cheapest place that i found it was here:
http://www.ecstuning.com/stage/edpd/...ory=Sway%20Bar
