newby with problems and queries
Old 04-24-2007 | 07:02 PM
unclebingo's Avatar
Default newby with problems and queries
Hi All.
Just bought a 2002 TT Quattro 225, in love with it already although it has developed asmall annoying problem
1.The drivers window seems to have a mind of it's own, if it is fully down and i try to close it it only closes 3/4 of the way and re-opens!!!
Am looking for uprated brakes, whats good on the market and where is the best place to get them from??
Also just like every other AUDI i have owned the bushes in the front anti-roll bars disentegrate fairly soon, is there any uprated bushes on the market which should nullify this problem?
Your help guys would really help.
Thanks.
Old 04-24-2007 | 07:07 PM
techbod's Avatar
Default RE: newby with problems and queries
forget the upgrades and concentrate on the window problem.
press the button to drop the window till it beeps then closes it till it does the same and do the same with all the windows,
has the battery been disconnected? if so that's why its called memory and in the hand book
Old 04-24-2007 | 07:14 PM
cincyTT's Avatar
I'm make believe
1) Hold the widnow down button until the window is all the way down and release it and press them down again. Then take the windows all the way up and release the button again and press it again. You may have to do this 2 times for it to work and if not lower the windows all the way down and unplug the battery for about 10mins and try again.
2) I have wilwoods on mine. 2 peice rotors with 4 piston calipers. you can get everything form jegs.com or if you want slid rotors from hotroduse.com.
3) check ecstuning for your bushings
Old 04-24-2007 | 07:16 PM
unclebingo's Avatar
HI Dave.
Thanks for your reply, i have tried opening, shutting using the buttons and also with the key fob but it still does the same....
Dont think he battery has been disconnected!
Old 04-24-2007 | 07:18 PM
unclebingo's Avatar
Thanks man...
adamsteinmetz
12-10-2012 06:40 AM
Rocksolid-fq430
05-25-2011 05:04 PM
blumango
05-12-2011 12:28 AM
Graeme2812
08-08-2008 01:32 AM
DUBPORT
08-08-2007 11:20 PM
