New intake..$98.00! :) .1 1/2 more pounds boost :)
Old 06-09-2007, 04:05 PM
Blown87camaro's Avatar
Default New intake..$98.00! :) .1 1/2 more pounds boost :)
Installed the new intake.... Velocity stack and Blitz Cone filter.... Grand total!??? $$ 98.00
I think it looks prety good...I got a breather for the pump hose also but....when i took the top part of the Stock filter box off i noticed HEY..... I can keepThe stock Bottom part of the boxin here and it may actually work better cuase the new filter comes reaaaly close to the factory cold air intake with it in.... and I dont even have to remove the stock breather from the air box Sounds supppppper loud and Car peaks @ 21-22 psi and settles to 19
[IMG]local://upfiles/33001/D95709BEE4194E93A0E4D77C13F60681.jpg[/IMG]
[IMG]local://upfiles/33001/8A6C28316D784827863FAE005CFA383B.jpg[/IMG]
Old 06-09-2007, 05:51 PM
cincyTT's Avatar
I'm make believe
Default RE: New intake..$98.00! :) .1 1/2 more pounds boost :)
not bad
Old 06-09-2007, 06:41 PM
Thanks....I Got my timing belt kit installed yesterday 620.00 out the door .... And was waiting around and saw a 6 inch Blitz filter in the glas case.... and said hey what size stack is on that he said 3" to 6" i said sh$# that will work... so i Tried it and my car turned into a jet....i waqs really suprised that i got another almost 2 pounds of boost.... And the bottom filter box works good instead of having a huge hole there
Old 06-09-2007, 11:26 PM
Im just curious after seeing how well this flows.... as to why people spend 250-300.00 for the same maybe even less air flow... All for a little heat reduction? Which the intercooler willcool before it goes into the motor anyway ?
Old 06-09-2007, 11:44 PM
cincyTT's Avatar
I'm make believe
i have been saying that for a...LONG time now. Then only thing i came up with is that they are all into heat deflection and/or its the lemming effect. You turbo needs airflow to make boost, not 10* cooler air.
Old 06-10-2007, 03:24 PM
225tt's Avatar
Do what you did, and add water/meth injection and you have all the cooling power you need. That and a good FMIC.
Old 06-10-2007, 09:41 PM
theTTkid's Avatar
haha well, i think some people do intakes simply for the sound...
Old 06-10-2007, 09:54 PM
cincyTT's Avatar
I'm make believe
then put a $30-50 filterfor the maf, dont spend $200-300 for an intake.
Old 06-10-2007, 10:30 PM
ORIGINAL: theTTkid
Then i need to get a sound clip of mine....cus i guarentee its louder then any modshack filter or CIA lol Its LOUUUD still 98.00 And washable
Old 06-12-2007, 02:06 PM
zachaTTack's Avatar
cool man i might do this im getting new exhaust tonight and i will still have about $250 to spend on my car so i think i will do this and boost gague
Quick Reply: New intake..$98.00! :) .1 1/2 more pounds boost :)
