New DV, Still only spinking to 11psi in a 225q
Old 05-08-2007 | 01:54 PM
randomloginname's Avatar
Default New DV, Still only spinking to 11psi in a 225q
i replaced the dv because i wasnt getting the boost i expected to see, i have an 01 225q and am only seeing it hold 5psi and spike to 10-11psi. the forge dv def made some difference in spool time and boost recovery, but it didnt change the max boost i saw, so i assume i have a leak somewhere. i know i couldve flipped the bosch dv(thanks cicny) but i know i want to chip it later so i replaced the dv anyways in case that was the issue, apparently its not. i dont have a compressor so i dont know that ican check for leaks that way, other reccomendations? thanks.
Old 05-08-2007 | 02:14 PM
MeanAudiA6's Avatar
Default RE: New DV, Still only spinking to 11psi in a 225q
thats the normal for a non-chipped 225 but it should settle more around 8psi....green spring? replace all your vaccum hoses....get the starter kit from hose techniques.com you will have plenty left over
Old 05-08-2007 | 02:17 PM
I have the red in their I believe, whatever one was installed default since i'm unchipped. Thanks for the advice,I will check the kit out. I had in my head that I should be seeing up to 16 un chipped for some reason.
Old 05-08-2007 | 02:48 PM
MeanAudiA6's Avatar
get that red spring out asap!!! it will damage the turbo!!! red spring is the strongest spring!!! made for high boost apps like 30-40psi
Old 05-08-2007 | 06:33 PM
i biked to work so ill have to check later for sure: :P for the 225 unchipped, i should have the yellow one or the green? green for 5-15, yellow 15-23psi? oh man [8D]
Old 05-08-2007 | 06:36 PM
cincyTT's Avatar
I'm make believe
Just stick in the yellow and if you chip it later, you may only need a shim.
phatboyfromla
12-14-2010 09:27 PM
fumoazul99
07-12-2009 11:08 AM
myslow1
08-31-2008 12:04 PM
boosTT 225
07-10-2008 01:41 AM
Race2win
10-01-2007 01:03 AM
