Need help plz (Radiator & Cylinder Head Gasket)
Hi,
Shop finally figured out what's wrong w/ my car, they said
I need new radiator and cylinder head gasket - I hope they are right this time...
(I had overheating problem since last sep, I replaced heat hose, flinge, coolant flashed 4 times, water pump, senors, and etc..)
I was looking at the ECS tuning.
Victor Reinz - Cylinder Head Gasket Set
http://www.ecstuning.com/stage/edpd/...ategory=Gasket
Valeo - Radiator
http://www.ecstuning.com/stage/edpd/...tegory=Cooling
It is good choice? or recommand something else?
Thanks,
Valeo - Radiator
Thanks,
You shouldnt need a rad unless the old one was leaking. If you blew a head gasket, im sure you would know. Car would run like crap and you would have oil in the coolant along with it getting low fast
Thanks
Thanks, Cincy TT
I just talked w/ shop about that they said found crack on radiator and
number 2 ,4 cylinder damaged by coolants & water. They also said i can not
buy regular head gasket because they have to see thickness of head gasket
and test out some kind of cylinder compression and balance test. It will cost
me round $1600 - 2000, what do you think about that?
Thanks again!!
Thanks again!!
AudiTurbo
01-07-2014 08:03 AM
elilundgreen
12-31-2013 01:58 AM
evilkowz
10
06-22-2010 11:48 PM
