need a big favor from someone with aligned headlights.
I'm going to need to align my headlights when i get my car back, but i have no specs as to how they're supposed to be aimed.
If someone with a camera has a few minutes, could you measure off 30' from the nose of your car to a wall on level ground, and measure how high up the beam gets cut off for both drivers and pass headlights?
Gotta cover one while you measure the other, so i can set each one.
It'd be a great help if someone had the time to do this.
RE: need a big favor from someone with aligned headlights.
http://www.ross-tech.com/vag-com/car...alignment.html
Hope this helps.
Hope this helps.
Was just on my way out the door on a beer run- here are mine:[IMG][/IMG]
Drivers side was 32 inches Passenger 42, don't know if this is factory spec, I didn't notice any change after I had them out for clear corners. Glad you fixed the TT and are still a part of the community, HTH.
Thanks! Don't care quite so much if its exactly within the factory specs, but after having the whole front end apart, i needed somewhere to start.
much appreciated. enjoy your beer.
