my roof stop working
Hello guys am new here and i need help with my electric roof
after some problems of opening only 1/3 or 2/3 and sometimes fine, now has stop working, when i am pressing the switch i can here a sound from the rear but is not moving also when push it with my hand its closing fine, can anyone help me with that?
Yes I have the same problem. It seems that the Hydraulik motor is not working or that there is not enough fluid. the problem is that you have to remove the top to get to the part....I just replace the top three months ago and now I am being told it would cost around $1600 parts and labour....
wow , so many problems on the new ones?
Glad I have an 02.
I put silicon on all the moving parts and wipe the rubber trims.
Needs baby care just like a garage door if you don't want the motor to die anytime soon.
Glad I have an 02.
Actually make sure you dont have a leak in your roof....My top, windows, and interior light stop working and what happened was that the water went down under the rear carpet and made the relays to stop working. The whole unit is $460> i ended up going to a junkyard and found the same relay but that is very rare to do lol. goodluck
thanks for you reply now you give my a good hint, when i am washing the car with the pressure machine and checked under the roof the mat is wet i think i got the same problem with you but only with my roof
