my flexpipe is broken. I need to know what part I need to replace it. I have a 180 with 225 exhaust.
Old 06-14-2007, 02:51 PM
chosos's Avatar
Default my flexpipe is broken. I need to know what part I need to replace it. I have a 180 with 225 exhaust.
Flexpipe is bad - downpipe moves freely and is held up by part of the underbody. I need the portion from the turbo to the cat, right? it has fitted pieces on each end that bolt in, right?
Can I use a 42 dd downpipe as a replacement? basically - what is the difference between that section on a 180 and a 225? I have a ko3s, but i have a factory dual exhaust (yeah its factory as my vin indicates.. i know 180's have singles... i dont get it either).
or... would i need the "OEM Downpipe Assembly ES#6297 $374.27" from ECSTuning (or somewhere cheaper)?
Old 06-14-2007, 05:01 PM
cincyTT's Avatar
I'm make believe
Default RE: my flexpipe is broken. I need to know what part I need to replace it. I have a 180 with 225 exhaust.
a custom built one would be cheaper and you can get it in 2.5" or 3" and gain about 10+hp. Also no, the 225's have a differnt turbo and outlet flange so it wouldnt fit.
Old 06-14-2007, 05:08 PM
chosos's Avatar
well, I need a comercially available option because insurance is paying for it. I can go aftermarket or oem.
Old 06-14-2007, 07:27 PM
cincyTT's Avatar
I'm make believe
Ask them if they will give you $350 or something less to have one made. As of now no one makes a dp for the 180q and paying $375 for a stock peice is just not right.
Old 06-14-2007, 09:56 PM
chosos's Avatar
well, is the cat different on the 180 vs 225? i mean, my dp on the 180 bolts right up to the 225 catback. Or.. will i need to replace all the cat, too?
Old 06-14-2007, 10:27 PM
cincyTT's Avatar
I'm make believe
both have twin cats, but the turbo has completly differnt turbine housings and location of the flange(ko3(s) 4bolt facing down, 225 3 bolt out the side) so if your thinking ofusing a 225 dp, again, not going to work.
You could also get a 42dd 225 dp and sell it for the funds to get one made.
Old 06-15-2007, 06:13 AM
chosos's Avatar
well, insurance is paying for the part though, and the shop needs to actually fix the car. Where can I get the 3" ends so I can have them possibly make me a downpipe. He said he is willing to do anything, but it has to have a cat on it. He said he was looking at parts and was quoted ~900, so i'm not sure what they quoted him on. I thought the stock DP was ~325.
Old 06-15-2007, 10:06 AM
chosos's Avatar
Cincy, will this work?
http://www.atpturbo.com/Merchant2/me...Code=AUDIVW-DP
Old 06-15-2007, 11:46 AM
cincyTT's Avatar
I'm make believe
Thats a fwd dp, wont clear the haldex. Most customes i have seen are around $400 with a cat, find a shop to make one for near that and tell insurance you will pay the differance. The 180q is a bastard child in the aftermarket, very little is made for them. Let them know that.
Old 06-15-2007, 12:37 PM
chosos's Avatar
drats. I dont think having a custom job is an option, at least according to the shop. They need to order the part and perform the installation. If there isnt a comercially available DP or something they cant mod at the shop, then stock it is.
Quick Reply: my flexpipe is broken. I need to know what part I need to replace it. I have a 180 with 225 exhaust.
