more boost
RE: more boost
what cooling system malfunction? the car is definitely in limp mode... what is the mileage? have you checked your plugs/coilpacks?
you would usually throw a misfire code for the coil/spark plug problems.
check all your turbo lines, too. might have a leak. keep us posted....
RE: more boost
Hmm dont really think it would, is there only one code being thrown? Do the ECU reset and then see if anything else popps up or if it fixes it. The coolant sensor is only for startup then it should be fine after the car warms up. Remember your 02 sensor could be going out as well. Take it somewhere get the code numbers and then let us know what they are.
BUCKET O BOLTS
07-28-2008 09:15 PM
eliTTe
10-11-2007 05:12 PM
