more boost
more boost
Well I just got an 02 tt quatro (180)and it lacks power. So I decided to hook up a boost guage (connected it to the vacume line off of the waste gate) and it only reads 5-6lbs for boost.Thishas tobeincorrect,if notcan I use a manual boost controler to increase the boost to 11-12 pounds?
RE: more boost
theres a thread around here somewhere that covers all this. Do a search and find it. this topic is very very common and theres 34,625,346,245,732,457,356,736,573,567,567,435,784 ,567 threads about it on the forum.
RE: more boost
5-6 psi means that your car is in "limp" mode. It means that the ECU will not allow anything more than 5psi. If reset your ecu, by disconnecting the positive off the termainal of the battery, wait about 15min then hook it back up and drive and see if you notice more power. If not then there is something wrong with the car and you need to get it checked out. Make sure you know your radio code beacasue it will be locked when you hook your battery back up. Good luck.
