MD/DC/VA GTG this weekend April 5th
Ok so this is posted in the "South" section, but I know not many people frequent that. So moderators please don't remove this!
So here is more info on the Baltimore GTG spot before we head to AtSpeed
Check out this event http://atspeedmotorsports.com/Events/p2_articleid/82
There should be over 100 porsche, bmw and audi owners in attendance.
Take I-95 to Key Highway N (if you're going northbound on 95 this will be the last exit before the Ft. McHenry Tunnel, likewise if you're going southbound it will the first exit after the tunnel so go into the rightmost of the two tunnel bores)
Key Hwy will make a 90 degree left hand turn and you'll come up to Lawrence St. Make a left and that signal. Go Straight on Lawrence and that will put you in a large parking lot with a Shoppers, Blockbuster, Tire Place....
We'll try and set up as far away from the stores as possible, so actually probably right away in the middle when you drive into the shopping center. McDonalds is on your left and they have a large parking lot which isn't ever crowded. So meet up there.
If anyone gets lost or anything, give me a call 301-980-0617 - Aaron
Remember we'll be meeting up there around 11, checking out rides/getting food if you're hungry/chatting for a while and then heading to AtSpeed right around noon.
If you can't make it that early meet us at AtSpeed, its a 15-20 minute drive from Baltimore.
