lowering springs and stock struts?
i have an 03 fwd and i was wondering if i can put in lowering springs( h&R neuspeed etc..) with my stock struts/ shocks ? i hve 78xxx miles on my tt currently, id replace all the bushings but jst wondering if the stock struts would be ok thnx in advance -Rich
They are at the end of their lifespan and if they are still ok, they will be working harder and go bad faster. New stock replacements should be fine with a modest drop of an inch. Just not something you want to do twice. If money is tight, at least do the fronts since the rear shocks are a easy to swap.
i live in a town with a ton of potholes so i dont want to be scrapping everytime i hit a bump but my tt would look sooo nice lowered
i just installed eibach pro kit about 1" lower, and new koni FSD shocks + struts, did rear myself alignment shop did front with 4 wheel alignment, even doing yourself you need an alignment, even if you get plain jane struts and shocks your better off with all new parts. update VERY nice car handler better and a nicer ride, although 37xxx on stockers 11yrs takes its toll, car used to thump when i hit a rough spot, not any more, labor is same to install any setup even if your stock almost stockers go back on
kwheels
10-28-2013 10:23 AM
Audibility2run
02-24-2012 11:57 PM
