liquidTT now has a black fascia option...
#22
RE: liquidTT now has a black fascia option...
There is a very technical tool used to do this. Doctors refer to them as Phalanges...
Step 1, strategically place Phalanges around the edge of the aluminum ring.
Step 2, with steady, even pressure, apply a "pull force" to the aluminum ring. Note that a sensation may be felt on the Phalanges at this time.
Step 3, stop pulling when the vent is in your hand
Yes, it is that easy (and Phalanges = fingertips)...
#25
See link for functions...
http://racediagnostics.com/cms/uploa...C_LiquidTT.pdf
A short list:
l Engine crankshaft bhp
l Engine crankshaft torque
l Turbo boost pressure
l Turbo command pressure
l Mass airflow
l Air–fuel ratio (Lambda)
l Air intake temperature
l Exhaust temperature
l Coolant temperature
l N75 position
l Engine misfire
A short list:
l Mass airflow
l N75 position
l Engine misfire
#27
Still not sure why everyone is so ga-ga over this. It still cant do all that a vagcom cable from Ross-tech can do. I guess people rather have flashy stuff than what they really need.
#28
Always there and always at hand is extremely convenient. Also saves mounting a couple gauges that rarely need to be used. Also of note, upcoming software release will support "limit" changes to gauges. If you reach a threshold value on a particular gauge (oil temp, for instance) that gauge will pop on screen...
Replacement for VAGCOM, no. WAY more useful than any other gauge you can stick in a vent, Heck Yes!
