Limp Mode - Codes.......
Old 09-29-2008 | 05:10 PM
shkenned's Avatar
Default Limp Mode - Codes.......
Finally got my check engine light cleared and thought I was in the clear, but ended up throwing another light, so here's what I have, any help would be appreciated:
P1128, P0300, P0303, P0304
In the past week (in order to clear the check engine light) all 4 sparkplugs were changed, both 02 sensors were changed, fuel filter was changed, and MAF is relatively new (within past month). Any ideas? Coil packs? Anything would be greatly appreciated
Old 09-29-2008 | 07:00 PM
shkenned's Avatar
Doing some reading, should I try running it w/ an unplugged MAF?
Old 09-29-2008 | 08:05 PM
shkenned's Avatar
Also, my car is chipped and we didn't adjust the spark plugs at all when we put them in, also part of it?
Old 09-30-2008 | 10:17 AM
shkenned's Avatar
Bump...
Old 09-30-2008 | 10:34 AM
MCPaudiTT's Avatar
You should certainly check plug gaps. Bad gaps will cause issues. They won't make you run lean, though, and neither will coil packs.
Your codes (you can look them up here in the future http://racediagnostics.com/cms/uploa...01_06%20.pdf):
17536 P1128 Long Term Fuel Trim mult.,Bank1 System too Lean
16684 P0300 Random/Multiple Cylinder Misfire Detected
16687 P0303 Cyl.3 Misfire Detected
16688 P0304 Cyl.4 Misfire Detected
So, you are lean, and running like crap. I would work on the lean - look for a massive leak somewhere in the intake system.
Old 09-30-2008 | 12:25 PM
shkenned's Avatar
Alright, the misfire's only came up after the last bit of working on it when we did the O2 sensors and fuel filters. The running lean code has been re-appearing regardless. When you say a massive leak in the intake system, any usual suspects I should look at?
Old 09-30-2008 | 01:12 PM
shkenned's Avatar
Attempting to find leaks, not found anything yet. Runs rough on startup (after sitting for a while) for about 20 seconds, then is fine. Vacuum at 20hg....
Old 09-30-2008 | 01:47 PM
shkenned's Avatar
Also ran it with the MAF unplugged - no difference there.
Staudi911
01-15-2015 04:20 PM
Nicholas Jeremiah Kleutsch
07-21-2012 08:57 AM
cmy225andlose
03-16-2012 07:39 PM
a4vt1.8t
01-04-2011 06:57 PM
jjcrt2
09-19-2009 06:40 PM
