Lighter flywheel question
RE: Lighter flywheel question
I just got a spec stage II+ put in with a lightflywheel.
It doesnt seem much different to me for everyday driving, but you will hear some chatter from the flywheel if you get the light wieght one
I just put in a spec stage 2+ withthe lightenedaluminum flywheel. Chatter is pretty loud at idle and sometimes when you're slowing down in gear it will chatter. The clutch catches much sooner than it used to and I have to rev it a little higher in 1st. I love it though, it rips through gears much quicker, feels like it added horsepower. Which in a way it kind of did, seeing that it takes less power to turn the flywheel. As long as you have the radio on, it wont bother you. I've only had it on for a week now, so i'd say I wont even notice it in a couple more weeks. Go with he stage 2+ for the extra $40. I believe mine cost around $1080 shipped.
ORIGINAL: MeanAudiA6
use lemmiwinks to raise idle to 900-1000 rpms no chatter
an ebay cable is all you need to use lemmiwinks you dont need the vag software for it but its nice to have it I took the cheap route and just got an ebay one works great for lemmiwinks and clearing codes on the older vag software and thats about it
Also, will this one work?
http://cgi.ebay.com/ebaymotors/OBD2-...spagenameZWDVW
