Is this a legit FMIC?
RE: Is this a legit FMIC?
I think that a good FMIC which is bigger and where the air flow is directly on the fins will give you better results than an upgraded SMIC where the air flow has to findthe SMICin the engine compartment (the air getting hotter as its in the engine). A FMIC will cost about $900 on the average and if you replace both SMIC (225) then you have spent more over a $1000. The 180 should definately get a FMIC once they chip and do exhaust. The stock SMIC is a waste on the 180 once its chipped and you have done a couple of hard runs. I have the APR FMIC and even with a bigger turbo I feel the power there even after I have done several hard runs.
So what would be the map sensor size for the TTQC 225?
The tCarbon FMIC is less in price than one of these SMICs as well. I haven't heard much about the performance of the tCarbon FMIC. Im a big believer in getting what you pay for (to a degree), which is why I'm still kind of cynnical of the tCarbon.
Is there a way to run the FMIC in conjunction with the stock SMICs? Obviously it would require tons of additional piping/hose, but could it be done? and would it honestly be worth anything practical or would it just be a conversation piece at best? I'd imagine it would require an additional intake which would change your air volume dramatically into the engine. Unless they fed into the same **** somehow, thus creating an enormouse backpressure of cold air. nvm. lol
*** Note: Please keep in mind that Im an aircraft mechanic and don't know anything about vehicle operation theory. If this question seems absurd or like it's coming out of left field, it's because I don't know **** about cars. Just curious to the limits of creativity.
I think they would either need to feed into the same MAF/**** to keep track of the oxygen content (however, I dont know how that'd work since the MAF/**** is before the SMICs in the cycle of things)...
...or you'd have to run them in circuit. ie cool the air with the SMIC and feed it directly into the FMIC to be further cooled. Curious if that is possible. Im willing to try if it is.
