Just bought Tein Lowering Springs got a Question??
I bought all around 1' drop tein springs, has anyone used these b4 are they hard to intall in the TT, do i need any special tools, or anything. Is a 1' drop big on the TT?
Thanks
Eric
Thanks
Eric
RE: Just bought Tein Lowering Springs got a Question??
1" is a decent drop for a TT. If you dont have access to and air compressor for the top shock mounts, you will need a special tool/wrench to get it off. I dont remember if your fwd or awd, but here is some fwd links (just the rears will be different for awd, but still self explainitory.) The second link has the tool or wrench you will need if no air tools.
sping install
coilovers (has a better needed tool section)
also you should get some shocks also, if your stock arent shot by now, they will be shortly after install (3-12months maybe). Also if you are awd, you should get a 1/2 Kmac kit.
sping install
Im pretty sure you need a spring compressor to get the job done...
Quick Question... What made the tein springs stick out to you vs. the other ones (neuspeed, H&R, and so forth..) Im looking into getting my TT lowered between 1 and 1.25 inch... Thanks
yes, a spring compressor will be needed.... thought that was a given (hopefully)
tein makes very high end suspension kits (many for jap cars), i wouldnt mind having a superstreet kit with an edfc, but no such luck for a TT [:@]
i bought them cause there a good brand they were priced great, and the shipping is quick i looked around and my friend has the same on his mazada 3 hatch and it looks great
sycklylow
05-11-2014 01:49 AM
sycklylow
04-05-2014 12:18 AM
RED_01
11-17-2008 08:48 PM
