I've been "vagged" (VAG-COM RESULTS)
I posted on OhioVW.com for anyone local with a VAG-COM and found someone... He came by yesterday and pulled the codes from my TT. My CEL was on, so he pulled the codes, cleared the CEL and pulled them again... the CEL is still off as of now, but here is what I'm getting... ( deleted the parts with no faults)
VAG-COM Version: Release 512.1-UD
Saturday,25,February,2006,12:52:42
Chassis Type: 8N - Audi TT
Scan: 01 02 03 08 15 17 22 35 37 45 54 55 56
Address 03: ABS Brakes
Part No: 8N0 907 379 C
Component: ABS/EDS 20 IE CAN V003
Coding: 13504
Shop #: WSC 01236
2 Faults Found:
01279 - Longitudinal Acceleration Sensor (G251)
27-00 - Implausible Signal
57-00 - Electric Circuit Failure
Address 08: Auto HVAC
Part No: 8N0 820 043
Component: TT-KLIMAVOLLAUTOMAT D02
Coding: 00140
Shop #: WSC 01236
1 Fault Found:
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
30-10 - Open or Short to Plus - Intermittent
Address 35: Centr. Locks
Part No: 8N8 962 267 A
Component: Central Lock/Alarm D04
Coding: 15884
Shop #: WSC 01236
1 Fault Found:
01617 - Please Check DTC Memory of Interior Monitoring
35-10 - - - Intermittent
End --------------------------------------------------------------------------------------------------
Coding: 13504
Shop #: WSC 01236
2 Faults Found:
Coding: 00140
Shop #: WSC 01236
1 Fault Found:
Coding: 15884
Shop #: WSC 01236
1 Fault Found:
RE: I've been "vagged" (VAG-COM RESULTS)
More or Less, I was just looking for any ideas as to which part this might be? Could it be something really small?
2 Faults Found:
2 Faults Found:
None of those codes will trigger a cel. As for the abs code, it sounds like a possible sensor failure. Not very common but ive seen it a couple times. I would clear it and see if it comes back. With the hvac code, i would run basic settings 1 and 2. If they run ok i would worry about it. There probably isnt a problem with the system. As for the central locking code, its probably an alarm triggered by one of the interior monitoring sensors. Personally none of those codes are serious and most of them can come up when there is nothing wrong with the vehicle. I would clear them all and look into them further if they return.
ORIGINAL: dankhound
ORIGINAL: dankhound
Probably something only the dealer is going to be able to look at, huh?
00604, 01236, accelaration, acceleration, audi, basic, dtc, g251, hvac, longitudinal, sensor, settings, tt, vag, vagged
