installing boost gage. ?
Old 03-23-2008, 12:30 AM
themysteryman83's Avatar
Default RE: installing boost gage. ?
I used Ryan's second link for mine and have had zero issues with it. It works greaTT!!! haha
Old 03-23-2008, 08:12 AM
JettaRedII's Avatar
ORIGINAL: tom1222
... The damn tubing kit from 42DD doesn't really work with the in vent installation. The vent tunnel in the back of the gauge
requires the tubing to take a sharp 90 degree turn which totally kinks that hard tubing from 42DD. I guess that was a waste of money.
Why don't you try a short piece 2-3" of rubber vacuum line of small enough diameter to fit the rigid line snuggly inside. That will let you bend it which ever way you need.
Old 03-23-2008, 09:43 AM
tom1222's Avatar
ORIGINAL: JettaRedII
ORIGINAL: tom1222
You may have something there. Perhaps I can use a piece of silicone tubing inbetween and us it to make that bend. and secure with zip ties. Hmm. I will give it a try now.
Old 03-23-2008, 12:07 PM
JettaRedII's Avatar
That's what I did. You can even get like 1/8" ID washer tubing.
VWs in the mid '70s used rigid vacuum lines that had rubber tubing for the junction points and bends. It was a stupid design because the rigid stuff would break and crumble after 5 or 6 years. That was the era when VW almost lost it.
Old 03-23-2008, 02:51 PM
joshuo's Avatar
ORIGINAL: tom1222
I just have mune running into the vent duct, make a lazy 180 in there, and then coming out the same way.
kinda like this:
Old 03-23-2008, 03:07 PM
tom1222's Avatar
Cute fingerpaint [8D]
I ended up putting a 6mm rubber tubing over the screw on fitting and then slipped in the hard tubing into the rubber tubing and zip tied the
whole thing. So far so good. Working like a charm
bikejumpr2020
04-14-2010 09:06 PM
audianthony
07-18-2008 09:07 PM
4RINGSROD
03-19-2008 12:38 AM
gunnenator
04-23-2005 07:50 PM
aaronamericahall
01-26-2005 03:24 PM
Quick Reply: installing boost gage. ?
