ignition coil wires
RE: ignition coil wires
ORIGINAL: cincyTT
Not sure what you are talking about here. If you are talking about the harness, you can, they sell complete sets, however im not sure how much they are.
I still have that stuttering problem at ~14lbs of boost. Code says it is a misfire, but I have changed coils and plugs. I'm thinking maybe the wiring going to the coils might be bad? The wires are pretty brittle from the heat and don't look to be in the best condition, plus some of the connectors have lost their locking tabs to hold them securely on the coils.
I would replace the plugs and make sure they are gapped correctly before changing stuff. You can get a new harness and just cut the wires as far back as needed and then solder in the new wires with connectors if you dont want to change the entire harness.
Juanma32
01-11-2014 05:06 PM
jedblack
07-27-2011 12:46 PM
drft1
07-05-2010 12:19 PM
