I need Intake Manifold torques and torque sequence... STAT!@#$%
Old 10-20-2007 | 11:24 AM
neur0tic's Avatar
Default I need Intake Manifold torques and torque sequence... STAT!@#$%
Long story short... I pulled the manifold, repaired the nipple, and now I need the torques and torque sequence for the manifold bolts on the Intake manifold (MK1 TT 225 quattro AMU 1.8t)
Anyone have this info on hand?
Old 10-20-2007 | 11:32 AM
diehlryan's Avatar
Default RE: I need Intake Manifold torques and torque sequence... STAT!@#$%
you just bought all that stuff (vag, lemmi.. etc) and didn't get a bentley manual?
Old 10-20-2007 | 12:25 PM
achTTung's Avatar
You could probably get away with torque specs based on bolt diameter rather than exactly what the manual says. Who knows, they may actually match.
I googled 'torque specs by metric bolt diameter' and this is one of the hits:
http://www.volvoclub.org.uk/faq/Imag...orqueSpecs.htm
As for sequence, just remember you're trying to spread the load, the same as if you were doing lug bolts. You could probably pick up any diagram from the internet for any manifold, or maybe even a valve cover, that has the same number of bolts/studs.
Old 10-20-2007 | 01:02 PM
MeanAudiA6's Avatar
i just did the normal diagonal sequence and tightend one turn past where its very snug
Old 10-20-2007 | 03:47 PM
neur0tic's Avatar
I got it from vortex. someone said to torque them inside out; that way the gasket wouldn't bunch up and kink. doubted it would anyway. But yea, its all done.
Old 10-20-2007 | 03:59 PM
cincyTT's Avatar
I'm make believe
inside out and snug should be more than good
Old 10-20-2007 | 04:07 PM
neur0tic's Avatar
It sure was. I couldn't believe how much difference in appearance it made just pulling the manifold off and cleaning it and the surrounding parts real well. Like night and day.
RaivisGertners
11-11-2018 12:15 PM
zoewagner
09-18-2013 06:36 PM
doityourselfer
07-13-2013 08:57 PM
paule67
08-05-2010 02:18 AM
paule67
06-13-2010 12:09 PM
